Stuck key in ignition
Old Aug 10, 2015 | 12:44 PM
2006A42.0TQT's Avatar
Default Stuck key in ignition
2006 A4 2.0T Quattro Tip. 140K
Attempted to get the ashtray out without removing the radio and a/c unit. After 1 hour of struggling to get it out, I spent another 2 hours trying to get it back in. Next morning I was headed out and noticed that I cant push the button on the shifter to get the car out of Park. Only after giving it more force while moving the shifter around (I heard/felt a slight thump, like something got unstuck underneath the still loose ashtray), I was able to get the shifter in Reverse. Arrive at my destination and found out I could not get the key out of the ignition. I looked under the ashtray and found a partial exposed wire (probably from rocking the ashtray in and out) that could be coming from the cigarette lighter.
Could it be the exposed wire causing the car's electronics to prevent me from getting my key out or could it be just a coincidence that something broke in the shifter or ignition?
Old Aug 11, 2015 | 02:04 PM
rhodes991's Avatar
I think something broke in the shifter. You should only be able to remove the key when the car is in park and I am guessing what ever thumped is causing the issue.
2006A42.0TQT
Aug 10, 2015 02:26 PM
Carl & Kathy
Feb 22, 2013 11:03 PM
deb123
May 16, 2011 07:39 PM
tibbar24
Feb 6, 2008 12:02 PM
midwestaudiA6
Sep 30, 2005 02:55 PM
