Tool to remove turbo diverter valve
Old Sep 23, 2017 | 08:01 PM
Hgk2's Avatar
Default Tool to remove turbo diverter valve
Anyone know if the 3 screws that hold the turbo diverter valve in on a 2006 A4 Quattro 2.0 are allen or hex? Also what size?
Thanks
Old Sep 28, 2017 | 08:15 PM
Hgk2's Avatar
Guess I will reply to my own thread now that the job is completed. Hope this helps someone else. Read somewhere else that it is easier to crawl under the car feet first. While it seems silly it is true. You get a much better angle at the bolts. I went out and bought several 5mm allen tools in both long, short, key, 1/4 and 3/8 drive, because I wasn't sure what I would need or work best. My recommendations on tools after just having done this is as follows- Do not use 3/8, use 1/4 drive. It is a tight fit under there, and 3/8 doesn't fit well. Get a long 1/4 drive 5mm allen ball end. The ball end and long allen is important, maybe a must. I would also recommend, although I didn't have them, would be a swivel head 1/4 drive ratchet and a 1/4 drive short swivel extension. Hope this helps someone perform the job more quickly.
07titanium
B7 Models
Oct 25, 2011 08:11 PM
dtmguy
Apr 16, 2007 03:24 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
mainer
Feb 25, 2005 01:51 AM
Firestarter1984
Dec 10, 2003 03:06 AM
