TPMS Problems, Error code 01833
Old May 9, 2013 | 01:52 PM
wayland's Avatar
Default TPMS Problems, Error code 01833
Hi All
This is my first post here, so bare with me. I got the follwing error code from VCDS, and i was just wondering, if i need to replace the antenna located at the rear bumber. I tried disconnecting the antenna, but the error code is still the same. If you need to full fault code scan please let me now.
I really hope someone have some input or things i can try in order to find the root cause of this problem. (And all 4 tires do have sensors) :-)
Thanks
Code:
Chassis Type: 8E - Audi A4 B6/B7
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0022222
   Shop #: WSC 06435 000 00000
   VCID: 2A511C7186E4089
2 Faults Found:
01521 - Sensor for Tire Pressure
            002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    (no units): 0.0
                    Voltage: 11.70 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    (no units): 0.0
                    Voltage: 11.70 V
                    (no units): 130.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Old May 14, 2013 | 04:21 PM
redcon1's Avatar
I had the error for no signal from multiple sensors also. I decided I could simply monitor my own pressures and disabled the TPMS via VAG-COM.
Old May 15, 2013 | 02:46 AM
wayland's Avatar
I have thought about that as well. I was just wondering if anyone could give any hints to what exactly was wrong, however I did some research and based on that, I believe that the sensors in the tires just ran out of battery power, while in storage over the winter.
I suppose that this is the procedure for disabling TPMS:
Code:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
Old May 15, 2013 | 01:06 PM
redcon1's Avatar
Yes, that's the procedure I used.
Old May 21, 2013 | 05:24 AM
wayland's Avatar
Thanks for the reply, the procedure worked as intended :-)
DCAV8R
Jan 23, 2023 06:33 AM
ProfileTrader
Apr 8, 2010 04:35 PM
NewJ_A4
Feb 3, 2008 01:09 AM
JCatt9
May 9, 2007 05:01 PM
Henrymcf
Jun 29, 2005 02:01 AM
