Am I being scammed? Please help :(
I'm feeling like the Audi service dept is scamming me.. I'm not sure if they messed something up or maybe because I'm a 25 yr old girl? Back story..
In Nov 2016 I bought a used 2009 A4 from a Mercedes dealership in Denver. It seemed to be consuming a lot of oil so I took it in to the Audi dealership in July this year. They said it needed the timing chain covers sealed because oil was leaking out. Thankfully, the EasyCare warranty I purchased from Mercedes covered the costs minus my $500 deductible. Everything was okay until August 26th I drove the car about 10 minutes from my house to church. When I went back out, the car wouldn't turn on. I had it towed to Audi and they said it needed the cylinder head valves and timing components replaced. This came to $5700. With lots of work, Easycare covered it again minus my $500 deductible. A week and a half ago they called and said my car was fixed and I could come pick it up. I got the car right around the corner (maybe 2 minutes) and the screen started flashing and beeping saying to turn off the engine and check the oil level. The computer showed the oil level as half way. It kept doing that alert about 5 more times back to back. I was on the phone with the dealership at this point and then the screen started flashing and beeping again saying not to exceed 4000 RPM. I was traveling at about 20 mph. They had me take it right back to them. Today they notified me that my car needed a new engine. Something about a balance shaft and bearings. Problem being, the warranty company would only pay total the amount that the car is worth, which they calculated at $8650. Easy care has already spent $6000 on the car so they'll only spend another $2600 and in addition to the new engine (which costs $9000), the warranty company would also require the engine to be torn down to find the point of failure so an adjuster can verify. That would be $2500. Obviously, spending $9000 on a car that isn't worth $9000 is crazy.. But i just bought the car and still owe $12000 on the car.. I don't know much about cars so I can't really tell if something is wrong with all of this. It feels fishy to me. They just got paid for $5700 worth of work that all was for nothing because now they have to throw it all out and put a new engine in it.
If anyone has any insight or advice.. please help me.. I'd appreciate it so much..
Thank you!
Thank you!
Something about the sequence of events is questionable. The second time they were mucking around with the timing chain/gear and when you received it back, you drove it for two minutes and had a massive engine failure. I suggest you sit down with the service manager and ask him to explain how they are not responsible when they just did this major repair followed by an almost immediate major failure. If they are not willing to work it out, then obtain all the paperwork and a lawyer.
Similarly, read the fine print on your warranty. They may not want to pay, but unless it states they will only pay up to book value then they need to cover the new repair less the deductible.
Good luck with both issues.
thesheldon038
Dealerships
Mar 9, 2011 05:23 PM
