Installation of Warning Triangle?
Old Jan 1, 2013 | 04:13 PM
rmorin49's Avatar
Default Installation of Warning Triangle?
I have a warning triangle that I'd like to install in my A4 but after doing some research it appears that installation requires removing the trunk deck liner. Is this the case? In my BMW 335 all I had to do was remove a couple of plastic blanks and install the brackets into some pre-drilled and tapped locations in the trunk lid. I see that ECS Tuning sells a kit with the triangle and a mounting bracket or you can purchase the bracket alone. I don't want to remove the trunk liner and was wondering if there is another way to mount the bracket by simply screwing the bolts into the liner and securing the bracket to whatever is under the liner. Does anyone know if this is feasible?
Old Jan 7, 2013 | 11:00 AM
hiwords's Avatar
yes you have to remove the trunk liner and put a some holes in it too. the holes are in the trunk lid but not the liner.
i don't think simple drilling into the liner will be strong enough to hold the triangle, honestly i wouldn't chance it and just do it properly.
on a side note, why not just stick the triangle in the spare tire well?
Old Jan 8, 2013 | 09:27 PM
rmorin49's Avatar
Agreed. Not worth screwing up my car for the sake of a triangle. I'll just put it in the spare tire well. After driving BMWs for the last 25 years it's nice having a spare tire for a change.
Euge82
Jun 26, 2014 11:12 PM
prospero
B7 Models
Mar 13, 2011 01:37 PM
b_foote1
Feb 7, 2010 07:19 PM
Cappachinoo
Jun 23, 2008 04:46 PM
Sunset350ZR
Mar 13, 2008 11:34 AM
