Lots of codes after Timing Chain service!!!!
Old Feb 21, 2019 | 05:52 PM
jbos333's Avatar
Default Lots of codes after Timing Chain service!!!!
Hello,
I'm hoping someone may have some insight on my issue.
2009 A4 went to dealer for shaking at idle, running rough, etc.
Diagnosis - Timing Chain stretched/Timing jumped
Replaced timing chain, 2 tensioners, 2 rails. Inspected cylinders - OK.
Payed the $1700 bill, drove about 10 miles away, CEL is back on. Rough idle again.
Plugged in scanner- 9 codes- PO300, PO301, PO302, PO303, PO304, PO506, P2187, C1555, P2279
Unfortunately, this is not my vehicle, and I have no idea what the codes were before the repair.
This is a friend's son's car. I have called and left a message for the dealership service department, but I was wondering if anyone has any helpful hints as to what may have happened.
Thanks in advance!
Jay
Old Feb 21, 2019 | 06:15 PM
jbos333's Avatar
OK I talked to the service department. They had apparently discovered the rear main seal was leaking/sucking air AFTER the $1700 timing chain replacement.
They claim that the codes I listed previously are a result of the leaky seal.
Is this possible?
It sucks because this 18 year old kid just spent a ton of money getting it fixed (or thought he was) and basically is back in the same spot.
The rear main will probably cost more than the timing chain I'm sure.
Thanks again!
Jay
Old Feb 21, 2019 | 06:48 PM
jagtoes's Avatar
Is this possible?
Thanks again!
Jay
Sorry but I don't buy it. A leaking rear main seal will leak oil out and not suck air in. Also if it did it wouldn't affect the running of the engine. They screwed something up and don't want to own up to it. Get in touch and arrange a meeting with the service manager and the GM of the dealership. You may also want to contact Audi of America. and have a rep available. All of the codes are ignition or timing related.
Boober
Oct 13, 2013 10:59 PM
moneyfresh
May 29, 2013 05:48 AM
carman222
Mar 18, 2012 03:11 PM
bdawg4snow
Jun 16, 2011 02:25 PM
aarono_120
Jun 28, 2010 06:19 AM
