low-beams too high?
I have a 2014 A4 Quattro. It seems as if my low-beams are set too high. i've noticed a lot of oncoming drivers will flash their high beams at me thinking that I have my high beams on. Is there a way to adjust the level at which the low beams point? when I start the car the headlights actually move up and down so i'm assuming it's computer controlled. is this complicated to fix?
First, I am no expert here, but my A6 has autoleveling headlights (no longer operative). I am pretty sure that since they adjust for load, they will compensate for any manual adjustment you try and make. Secondly, since you probably have HID headlights, you will find their brightness often confuses other drivers into thinking you are driving with your high beams on. A quick flick of the lever to flash your real brights cures that misconception.
