Tire Size Based On Rim Dimensions
Old Feb 27, 2012 | 10:23 PM
Nick_UltraSport's Avatar
Default Tire Size Based On Rim Dimensions
Hey Friends,
How do you tell what the tire size will be based on the rim specifications?
These are rims specs: 20" x 8.5", 5x112mm Bolt Pattern, +44 Offset, 66.56mm Hub
But how do you tell what tire this will fit on?
Thanks for your help guys.
Old Feb 27, 2012 | 10:41 PM
derZeck's Avatar
All depends upon you, some will say you can stretch a 215 on there and others will say run 255's.
Questions that will be asked.
What is your stock tire size?
Are you lowered?
How much do you want to spend?
Old Feb 27, 2012 | 10:47 PM
Are you lowered?
Hey thanks for reply. My stock size is 245-45-17. I am not lowered and for the spending I want to get good tires but i Dont know what size to put on the rim.
Thanks again.
Old Feb 28, 2012 | 05:52 AM
shipo's Avatar
For a 20" rim the best size to go with to keep your speedometer and odometer accurate is 245/30 R20. That said, why on earth would you want to put those monstrosities on your Audi? Not only will they negatively affect both ride and handling, with only 2.9" of sidewall height you'll blow out a tire and/or bend a rim if you so much as run over a small rock in the road.
Old Feb 28, 2012 | 09:21 AM
Shipo - The reason I am going to 20" is because the rims that I am interested in Vossens they only come in 20" and to me they look sick on the car... Do you have any suggestions on other wheels? I like the concave look of it...
Old Feb 28, 2012 | 05:24 PM
Newbie88's Avatar
Be forewarned, if you put 20's on with a stock suspension setup, your car will look somewhat like a 4x4. If you go that big I'd lower it for sure.
To give you an idea, this is a pic on only 19's
Old Feb 28, 2012 | 07:35 PM
PAnick's Avatar
Vossen's will like great on your car, I would guess you're going with the CV3's? I think for your ride you will definately need to drop it, suggest Eibach lowering springs and at least a 245 tire size. I have 255 on my stock 19's. I would also suggest wheel and tire protection, those low profile tires are more prone to road hazzards and will cost you at least $250 per tire to replace, depending on the tire you choose.
shanechevelle
Oct 28, 2012 05:31 PM
mystrodo
Sep 2, 2009 09:41 AM
cvsmightymouse24
Apr 13, 2009 12:12 AM
fidelite
Jun 24, 2008 02:06 PM
SloRide
Jun 6, 2006 11:58 AM
