1983 Audi 5000 problems
Old Jul 9, 2007 | 05:08 PM
antibalas's Avatar
Default 1983 Audi 5000 problems
The problem i am having is after driving even for 5-10 minutes and shutting the car off it will not start back up again.
It also does not hold its idle well dies down then will not start back up for roughly 45min to an hour.
any ideas on what the problem may be and an estimate on the parts
Old Jul 10, 2007 | 07:37 PM
0fframp's Avatar
Default RE: 1983 Audi 5000 problems
The idle problem is probably due to a vacuum leak, the hard starting problem could also be the end result. It probably takes about 45 minutes for the engine to cool down sufficiently for the cold start injector to kick in. Check the system pressure and manifold vacuum when the engine is running.
Old Jul 10, 2007 | 10:59 PM
InExile's Avatar
yup start looking for vacum leaks ... rubber vacum lines are cheap
Old Jul 11, 2007 | 12:57 PM
antibalas's Avatar
what would be the best way to look for a vacum leak if the car cannot hold its idle
Old Jul 12, 2007 | 01:37 AM
InExile's Avatar
spray a can of brake cleaner all around and look for changes in idle .... fire it up and use a stick or somthin' to hold the pedal while your sprayin'
sneezlsrus
Jan 16, 2012 01:36 AM
sam1
Nov 11, 2010 03:52 PM
thefox
Sep 19, 2010 08:49 AM
chinook
Feb 18, 2007 05:16 PM
flAre
Mar 6, 2003 07:03 PM
