1990 200 TQ Starting issues
Old Oct 1, 2007 | 06:48 PM
ctkt52601's Avatar
Default 1990 200 TQ Starting issues
My car starts perfectly every morning and at my lunch break. When I leave work at 4 it takes about 30-45 seconds of cranking to start. First start is at 5am, second at 11am and I leave at 4pm. Please let me know if you have any idea what could cause this. Thanks, Chris
Old Oct 3, 2007 | 10:15 PM
InExile's Avatar
Default RE: 1990 200 TQ Starting issues
whats the temp change .... take good look at all the temp sensors
Old Oct 8, 2007 | 08:21 PM
ctkt52601's Avatar
Outside, 20 degree change. Motor is cold at each start.
Old Oct 9, 2007 | 11:19 PM
InExile's Avatar
20 deg is a big change ... so do check out the sensors ...
Old Oct 10, 2007 | 06:08 PM
ctkt52601's Avatar
Thanks I will. You know your stuff, a warning came up today showing an oil temp sign and I had just started my car. Which sensor do you think would be most suspect? Thanks again, Chris
Old Oct 15, 2007 | 05:36 PM
ctkt52601's Avatar
I found the problem today. I had my door closed when turning the ignition and it starts great every time. I guess when I was leaving work I would leave the door open and try to start car. Well the electronics are junk on this car but the performance makes up for it.Thanks again for your help.
stic
Apr 17, 2013 10:54 AM
jddrag200
Sep 15, 2009 07:17 AM
albqscott
Oct 24, 2008 11:49 PM
sypherz28
Jan 17, 2008 10:46 PM
gruey
Dec 30, 2005 11:58 AM
