1990 Audi 80 Not Starting
Old Jan 15, 2008 | 11:49 PM
sypherz28's Avatar
Default 1990 Audi 80 Not Starting
Okay here is my issue. First off I have never worked on an Audi in my life, but I 'have' worked on cars long enough to know that you need several critical things to make a car run. Air, Fuel, and Fire. I bought this car with no timing belt on it (thankfully its a non-interfearance motor) so that was the first thing to tackle. I'm 99.9% sure that it is timed just fine due to the compression im getting. The distributor is timed up okay and delivers a VERY hard spark. I removed one of the feul lines from the fuel distributor and it pumps out gas. And the air filter is nice and clean. It still does not start and I cannot for the life of me understand why.. I have noticed that it Reaked of gasoline when i first turn the key and believe me I know 100% there is no gas leak on the motor, so i can only believe I am smelling it comming back through the intake.. someone please assist me before I 'Make' a gas leak and set the car on fire..[:@]
Old Jan 17, 2008 | 10:46 PM
sypherz28's Avatar
Default RE: 1990 Audi 80 Not Starting
furthermore im told there is something wrong wiht the cold start valve.. and convienently there are no codes to be found.. is it possible there are sensors that could cause it to do this??
stic
Apr 17, 2013 10:54 AM
jddrag200
Sep 15, 2009 07:17 AM
albqscott
Oct 24, 2008 11:49 PM
ctkt52601
Oct 15, 2007 05:36 PM
gruey
Dec 30, 2005 11:58 AM
