1990 200Q/T trouble starting
Old Aug 25, 2009 | 09:14 AM
jddrag200's Avatar
Default 1990 200Q/T trouble starting
Now that it's summer I can get my car started whenever I need to. However, it still requires at least 5-20 seconds of cranking and pumping the gas pedal.
My real problem is when the weather gets cold. Last winter I killed my battery from having to crank the starter so much. Sometimes it would take 20 minutes to get her started, sometimes it wouldnt start at all.
I know the problem is something with the fuel delivery, but what exactly? I hope its not the fuel pump because I know thats expensive (can it be rebuilt?) I don't know know how to check if its the fuel pressure regulator without buying fancy gauges. I imagine its probably leaky injectors. If so, how hard is it to replace these? If I do that is there anything else I should try to fix while Im in there?
Thanks for the help!
Old Sep 11, 2009 | 08:17 AM
salleuxe's Avatar
Is it petrol engine?
Old Sep 11, 2009 | 01:11 PM
NH_USA's Avatar
I would look at the temp sensor that tells the ECM to make the fuel mixture richer when it is cold.
Old Sep 15, 2009 | 07:17 AM
jddrag200's Avatar
yes regular gasoline engine, where is the temp sensor located?
stic
Apr 17, 2013 10:54 AM
sypherz28
Jan 17, 2008 10:46 PM
ctkt52601
Oct 15, 2007 05:36 PM
jaredfromsubway
Sep 14, 2007 01:41 PM
gruey
Dec 30, 2005 11:58 AM
