85 UR quattro
Old May 3, 2016 | 11:05 AM
  #191
dave944's Avatar
I'm seriously thinking about replacing all the small screw-type clamps on vacuum lines with the spring clamps. Maybe on the coolant lines too.
Old May 18, 2016 | 01:09 PM
  #192
team illuminata's Avatar
Why??
Old May 18, 2016 | 01:24 PM
  #193
More tubes, more clamps, more money, more time. The four rings of (old) Audi ownership.
image by Team Illuminata Motorsport, on Flickr
Still, I think we are done with vacuum hoses
Charcoal canister is back on/in the car and replaced most of this:
The "S" shaped hose is NLA as is the little stubby that's actually a reducer, so I left those in place.
This section is all done too:
And I finally figured out the arrangement for the warm-up regulator after referring to and stealing some from my 83. Not sure why I didn't think of this before.
What shall we do next; put the engine back in maybe?
Old May 19, 2016 | 09:35 AM
  #194
dave944's Avatar
The spring clamps maintain constant pressure and continually tighten should the rubber hose shrink over time. Less likely to leak plus you don't have to worry about overtighening them.
Old May 24, 2016 | 04:52 PM
  #195
Decided to curb my enthusiasm and fix a few more things before impetuously throwing the engine back in. Someone had spliced in a new piece of wire at some point; quite poorly.
Fixed that.
This, however, can wait. It sits on top of the intake which makes it easier to repair in situ.
Found we are missing the heat shield over the right engine mount; the one that had failed. Of course its No Longer Available.
88d8fca54b29730e841a7e7696536fcc by Team Illuminata Motorsport, on Flickr
This is what it looks like in the flesh; OK on Google.
857199386a_857199386a_1 by Team Illuminata Motorsport, on Flickr
$_1 by Team Illuminata Motorsport, on Flickr
The we had a great idea; let's steal the one off the 83 in the corner. It was impossible to see but we managed to removing the mounting hardware, surprisingly. Even more surprisingly we managed to extract it without having to remove anything else!
Then, even, even more surprisingly it looked like this!
Obviously a cobbled together facsimile. What is odd, beside the strange tube is the fact that what's left of the original is still encased within. Obviously not going to work on the 85. Off to Audi Tradition to get reamed again.
Old Jun 11, 2016 | 05:35 PM
  #196
Waiting for parts (drums fingers on desk)
Decided to find some things we will need to do before the car is ready to fire up. Getting ahead so to speak. The hydraulic "bomb" mounts need replacing as the leaking oil has softened them up and they have started to split. Fortunately we bought some new ones a while back. A good time to replace them.
Fortunately the nuts weren't too rusty and didn't put up a fight. Sometimes leaky hydraulics has benefits.
Uh oh! this must have happened in storage DOH. Let's hope they bend back without breaking off. Perhaps we should order a new one anyway.
Old vs. new. A couple are still serviceable. We'll keep them for spares.
And back together.
And on the engine. Yes, it surprised us too. Well, we had to put it somewhere and the dodgy spade terminals we bent back into place will be safer here than back in the parts box. It shouldn't hinder engine installation and one more thing done
Old Jun 15, 2016 | 10:40 AM
  #197
Another update in less than a week. You guys must be feeling rather special now eh?
Just trying to find things to do while those damn heat shields arrive from Germany. Rummaged through the parts bins and found the old front brake lines that need replacing. Couldn't find any OE so decided to make these Centric ones look like OE by transferring the rubber rings over. What do they do anyway?
We actually had some we pulled off the 83 car. That one's getting stainless lines so we just cut the old ones which made getting these off quite simple.
However, getting them on the new lines was not so easy as they didn't want to expand over the fittings. Never mind, nothing a utility knife and some glue can't handle.
Wheel leave them to cure for a while eh.
We only need one holder ring so we cut one off. We decided to use the Centric one as our original ones are already falling apart.
Oh, is that the DHL truck?
Old Jun 30, 2016 | 09:07 PM
  #198
When we last conversed we were finding things to do while we waited for a heat shield to arrive from Germany. Well guess what; it arrived, along with a few other bits and bob. we must say, it looks a lot better than what we pulled out of the 83.
It was quickly installed but as soon as it was on we thought "Uh oh, we might have to take it off to get the engine in" DOH! well, we had no idea what it looked like until it was here so how could we know it might be in the way. Oh well, another month wasted.
So, not to waste any more time we quickly started to pop the engine back in. It was a little tricky to lift it into place as we had to guide it around a lot of stuff (but not that damn heat shield as we took it off) but eventually it lined up with the engine and subframe mounts and we bolted into place, hand tight for now.
This is the first time it's had an engine in it since February 2015! We have so much more room in the shop now.
What next then? We guess connect as little stuff as necessary to fire it up while refurbishing whatever is necessary. Stay tuned.
Old Jun 30, 2016 | 09:42 PM
  #199
dave944's Avatar
Looking good, man. I just got the new guides for my 5000SQ head and will be getting them installed this week. I hope to get the head on the engine and get it all buttoned up to go back in soon.
Old Jul 10, 2016 | 03:27 PM
  #200
Started to put the car car back together yesterday. Unfortunately it's been two years since we last saw where everything went so it's a bit of a challenge. Fortunately we have an 83 in the corner to refer to. Unfortunately, because it's a Quattro you can't see anything LOL.
Still, we press on regardless.
Aligned the engine and torqued all the subframe, engine and transmission bolts. Well, the ones you can get a torque wrench on.
connected the hydraulic pipe to the bomb. This connection does not seem to rotate so we took the bomb off and rotated that instead. This is now the third time we have installed the bomb.
Reconected the exhaust.
Reconnected the rear drive shaft.
Reconnected the shift linkage. Goes into all the gears but might need adjusting though.
Installed the right engine mount heat shield, again. It wanted to go in front of the oil cooler mounting tab so we mounted that too. I bet we take it off again later.
Installed the right transmission mount heat shield. Yes, we are missing a screw. It's like no other screw on the planet and seems to be NLA. Thanks Audi.
Reconnected the clutch line.
Not sure when we'll get chance to throw some more parts at it. Schedule is a bit full for the foreseeable future and the Tour de France is on TV six hours a day!
