91 audi 100 - Other starting problem, different from the other guy
Old 06-24-2007, 03:40 PM
rocksteady_racer's Avatar
Default 91 audi 100 - Other starting problem, different from the other guy
So sometimes when I try to start the motor it won't start up, even if the tank is full or empty or what level it is it has the same problem. Now your like well how do you get it started when you have this problem. What I do is I rock the car back and forth and it'll start up after that. It only happens sometimes and it's pretty random I think it depends on the incline of the hill I'm on. Anyone else have similiar problems and any idea what in esoteric audiworld it could be?
Old 06-24-2007, 07:59 PM
sdiegidio's Avatar
Default RE: 91 audi 100 - Other starting problem, different from the other guy
Have you changed the fuel filter?
Old 06-24-2007, 11:42 PM
InExile's Avatar
do you have a spark when it's not starting
Old 06-25-2007, 07:06 PM
Yep. First thing I did was replace the fuel filter. No luck there... Hmm spark when it's not starting, not sure, I should check out next time. Why what could that be? I do know I can hear the fuel filter turning on before trying to start it, and the starter going when I try to start it up but I'm not sure about the spark, think it might be bad spark plugs?
Old 06-25-2007, 11:03 PM
InExile's Avatar
well you need 3 basics for a combustion motor to work .... air , fuel, fire .... start with the bassics
Old 12-01-2007, 02:01 AM
rocksteady_racer did you ever find a fix for your problem? My audi just does not want to start. It was running great, then the next day it would not start at all.
A.P.
ChiselA3
05-22-2013 04:18 PM
dolceto
03-25-2012 04:09 PM
xxlbas
10-09-2010 10:27 AM
adam_schell2239
12-16-2009 03:19 PM
nooneau
03-29-2006 06:11 AM
Quick Reply: 91 audi 100 - Other starting problem, different from the other guy
