audi 100 1990 need to no how to enter code?
i have a 1990 audi 100 and its a nice car i must say i love it but the only problem si that i cant get the stereo to work because its in safe mode. I have the code but i do not no how to make it so i cna enter the code into the stereo. I really ned to get thsi cause the previos owner got a upgraded bose speaker set with the car but the stereo is stock i really need tunes please help. Thank you.
Delta fixed coded radio
Overview
As of model year 1990, Delta radios are assigned a fixed four digit security code from the factory. Unlike previous coded radios, the security code cannot be changed.
The fixed coded radios have been implemented gradually and can be identified by the part number. A part number label is attached to the radio chassis.
Delta — Part No. 893 035 093B
Delta Bose Part No. 893 035 093C
CAUTION
Part numbers are for reference Only.
Always check with your Parts
Department for latest information.
The radios are not coded at the factory. To activate the theft protection, the radio must be coded during the Pre-Delivery Inspection.
The security code and serial number of the radio are printed on a removable sticker located in the trunk near the vehicle identification sticker.
Coding a new or remanufactured radio
• remove radio security code serial number sticker from trunk and attach to radio card in operating instructions manual
CAUTION
DO NOT keep the security code or radio
card with the vehicle. Always instruct
customers to detach radio card from
operating instructions manual and keep
in a safe place
Note
The security code serial number sticker for remanufactured replacement radios comes in the box with the new radio. Place the new sticker over the old sticker on the radio card.
• switch radio ON
• radio plays and radio station frequency is displayed
• push and hold AM and ARI-Z buttons
• radio display changes to CODE and then 1000
• release AM and ARI-Z buttons
• 1000 will remain on display
• enter radio’s security code using program station buttons
• security code will appear on display
• push and hold AM and ARI-Z buttons once again until display changes to SAFE
Note
A new or remanufactured radio will Only accept its factory assigned security code, If an incorrect code is entered, the radio display will not change to SAFE.
• radio display changes to a radio station frequency
• radio is now coded
Reactivating radio after reconnecting power
After disconnecting power (fuse. battery, etc the radio will lock up electronically.
To reactivate:
• obtain radios security code
• located on radio card
• switch radio ON
• radio will not play
• radio display shows SAFE
• push and hold AM and ARI buttons
• display changes to 1000
• release AM and ARi-Z buttons
• 1000 remains on display
Note
If the AM and ARI-Z buttons are held down too long or pushed again, the radio will misinterpret the 1000 as an attempt at coding and one incorrect attempt will be logged
• enter radio security code using program station buttons
• release AM and ARl-Z buttons
• radio is now coded and plays
Unlocking an electronically locked radio
After two incorrect attempts at entering the securIty code, the radio will lock-up electronically. The display shows SAFE and will not change.
To unlock:
• leave radio switched ON for approximately one hour
• after one hour. reactivate (code) radio as it would be after a power interruption
Note
The radio will never permanently lock-up no matter how many incorrect coding attempts are made. The reactivation procedure can be repeated indefinitely.
Overview
CAUTION
CAUTION
in a safe place
Note
• switch radio ON
Note
To reactivate:
• switch radio ON
Note
To unlock:
Note
410ThirtyValve
Dec 9, 2014 09:25 AM
stephen4785
Dec 11, 2006 01:30 AM
