Audi 90 2.3 1989 almost stalling at idle
Old May 9, 2008 | 04:01 PM
menio's Avatar
Default Audi 90 2.3 1989 almost stalling at idle
Hey,
Since a day or two the engine of my audi stalls or almost stalls at idle. If it does not stall it will drop to about 200 rpm and wave a little around before setteling at 800. The problems seems worse when the engine has warmed up a little. Cold it will idle fine. Before it started the rpm's would not go below 1500rpm for a few minutes. It could be that it had a show circuit before the problems started because i drove through a big pool.
Do you guys have any idea what it could be?
Thanks!
Old May 10, 2008 | 12:24 AM
OchoCinco's Avatar
Default RE: Audi 90 2.3 1989 almost stalling at idle
I think it may be the Idle Screw Adjust valve. There is a sticker under the hood ( at least under my hood) explaining where it is and where it should be set to a certain range. My 5000 does that when its warming up. It sputter down to 800 rpm then goes up,down,up,down....
Old May 19, 2008 | 06:44 PM
Asphalt Unlimited's Avatar
It's your Differential Pressure Regulator. It's along your main intake tube, it looks like a little cylinder. If you replace that problem will go away.
Old May 19, 2008 | 10:16 PM
OchoCinco's Avatar
I swear, the more I read this forum the more similiar my car becomes to all the problems. I had a hard time starting it today. It started with what sounded like a backfire, prolly due to flooding,due to starting alot,, but it would go up to idle speed, stuttuer,try to climb back up but trip and die if I dint get the gas going. It idled cleanly after a while but its strange. I checked and there is a hole in the piping from the giant plastic thing with a 1inch hole in the middle that does god knows what to a pump looking thingy. When the car was running, I stuck my finger in there to see if it was an EGR but nothing, squeeze it nothing happens.
Do you have a picture of this Differential Pressure Regulator ?
Old May 20, 2008 | 07:02 AM
I don't have one and can't seem to find one online. but i will try to remember to take a picture of it on mine when i get to work today (as my car is at my shop awaiting me to fix it). If i do i'll put it up tonight.
Old May 20, 2008 | 12:39 PM
NH_USA's Avatar
Clean your IAC. There are numberous articles about how to do it.
After that look for a leaky vacuum line.
gerrydrumm
Feb 27, 2015 04:15 PM
killblazer
Apr 2, 2010 02:13 PM
corradophil
Nov 27, 2007 05:41 AM
ksouls
Aug 10, 2005 09:54 PM
BeerBaron
Apr 30, 2005 02:33 AM
