Electric coolant fan
yes i hope you find this to live up its title... if your fan runs all the time (even on startup from cold?) it is because your fan switch which is located in the radiator has shorted itself out. "Radiator Fan Switch" i guess it is - on my car it costed $46 thru auto zone. good luck
Last edited by 88A5TQ; Feb 1, 2009 at 12:39 AM. Reason: i felt it needed a set of "quotation" marks.
had the same thing happen on my 87 4kq replaced the radiator fan switch and all better. on the 4k it was a easy fix. just had to drain the radiator. pull the old switch out and put the new one in and then refill the radiator fluid after. good luck
Cioffie
May 19, 2013 10:24 PM
compman723
Jun 13, 2011 09:59 PM
ggavgg
Aug 3, 2009 01:28 PM
greyghost
Mar 28, 2006 02:58 PM
