electrical problem
the other night i was taking a friend home and i went to turn on my head light and my dash lights and heater/air lights shut off as well as the defroster light. but my subs kick on and the lights in the glove box turn on i dont know why this is happening it was just random. i checked all of the fuses under the hood. not sure if there are hidden ones.other then the relays under the gauge cluster. help please cant tell how fast i am going after dark
I had this happen once to me as well and realized that I had accidentally simply dimmed the dash lights. All the lights you speak of are on the same dimmer switch. The dimmer control is that post on the far right of the guages. It turnes right to brighten and left to dim.
Hopefully thats the problem.
ORIGINAL: frankinstyn
check the intensifier above the glove box- (looks like a relay) - these had bad solders inside causing eratic dash light performance. remove the intensifier but leave it plugged in and wiggle it to see if lights come back on... hope this helps
ditobot
Feb 6, 2012 10:51 PM
