Engine won't warm up?
Old Feb 1, 2007 | 11:31 PM
KSpark's Avatar
Default Engine won't warm up?
For some reason my '93 90CS won't warm up past the 1/4 mark...I've driven it for up to an hour at a time, but absolutely nothing higher. I just changed my filters and got an oil change, so I don't think that is the problem. Any ideas?
Old Feb 2, 2007 | 12:21 AM
TommyL's Avatar
Default RE: Engine won't warm up?
Sounds like a thermostat.
Old Feb 2, 2007 | 04:00 AM
InExile's Avatar
temp sensor or the fan is running too much ... bad thermostat or a bad water pump would command overheating
Old May 25, 2007 | 07:46 AM
salleuxe's Avatar
I have the same problem. Actually, sometimes it shows right temperature and sometimes subzero. For example, I start engine which is cold of course. Then after a while it shows that is still cold though it is obviously warm. Then I drive and in the middle of that, it rises and shows the right temp. Then I stop forcouple of minutes and turn off the engine,and start it again and it shows subzero again. It must be something about wire connections. Or, maybe even the gaugeworks occasionally. Anyway, method of elimination should be conducted.
Old May 25, 2007 | 07:52 AM
kakarot's Avatar
you need to check the thermostat, when you belive that the engine is hot, check the upper and lower hose for heat. The upper should be higher that the lower. the lower should be hot too.
if it is, then probably the sender is bad, or the sensor for the heat.
ammckay
Nov 14, 2017 10:01 PM
arneost
Jan 27, 2010 10:22 AM
biznets
Oct 19, 2009 11:27 PM
xav
Apr 4, 2008 06:52 PM
kraylon
Jul 25, 2007 01:19 AM
