fuel, fuel pump question
Old Nov 1, 2006 | 01:55 PM
TajMan's Avatar
Default fuel, fuel pump question
I've got a '88 Audi 90 4cyl, (manual swap from '89 80 4cyl)
The fuel pump is buzzing really loud. Still works now but I'll replace. What's a better choice to pull from the junkyard: one from a '90 80 4cyl, one from an '89 90 5cyl, or one from a '93 90 V6? Even with the stronger V6 pump, should something else keep the fuel pressure the same and extra flow just get returned? I thought the newer V6 pump was probably the best choice.
Right now the car has some kind of fuel problem. When you go too close to wide open throttle, especially when the gear is too high and rpm's too low, the engines sputters and misses bad. If you drive the car carefully, less than 1/2 throttle, you can get around everywhere with the engine running perfect and only stumbling maybe 5% of the time. Something with the mechanical fuel distributor? Fuel pump not supplying adequate pressure?
Old Nov 1, 2006 | 04:25 PM
InExile's Avatar
Default RE: fuel, fuel pump question
Well the fuel pump might be going out ... as far as the fuel pumps go check the fuel delivery rate and also a more powerful pump may need more electricity you could be setting yourself up for problems and your cis fuel system is going to need a check valve on or near the pump usually so that your feed fuel line doesn't leak fuel back into the tank
Old Nov 1, 2006 | 04:37 PM
techbod's Avatar
the newer Bosch pumps have a rubber grip round it so less or no noise so wrap the pump with rubber to ease the vibration, my merc did that and I fitted a pump out of an Audi " same pump " Bosch
Old Nov 2, 2006 | 02:49 AM
InExile's Avatar
I agree check the rubber thingy first ... if the pump has been replaced then some one might have skipped a corner
Old Nov 8, 2006 | 11:37 PM
TajMan's Avatar
Changed fuel pump and fuel distributor from a few year newer Audi 80 2.0L. Made things a little better, but still some issues. Used BG 44K fuel additive, AWESOME stuff, even better now but still some issues. Changed cap & rotor, still same. Plugs were new, waiting for wires now. Not sure what's causing the stumbling sometimes now.
Old Nov 9, 2006 | 01:24 AM
TajMan's Avatar
And now won't start, runs for just a sec off starter fluid. Nothing I can do except put the old pump back on I guess, see if that fixes, get a new pump from the junkyard. No more 2.0L 80/90's, does one work off a mid 90's 2.0L VW?
Old Nov 12, 2006 | 01:14 AM
lboudreau's Avatar
If you're getting hessitation or a stuter response from your engine it could be your injectors or maybe even your fuel filter. If your fuel filter is clogged your fuel pump has to work harder to pump the fuel which could cause your car to not work properly.
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
jsethwerner225
Nov 14, 2014 01:55 PM
DJmart
Aug 3, 2013 11:08 AM
sollyd25
Dec 2, 2011 07:39 AM
