Hub nut size for Audi 80 1995
Old Oct 27, 2005 | 05:51 PM
audi80v6's Avatar
Default Hub nut size for Audi 80 1995
I'm replacing the rear discs and a caliper at the weekend on my 1995 audi 80 2.6.
Just want to know the hub nut size so i can make sure i'm fully prepared.
Thanks
Ashley
Old Oct 28, 2005 | 02:23 AM
gmatov's Avatar
Default RE: Hub nut size for Audi 80 1995
If it's a front wheel drive, no socket needed. Easy to remove with slip joint pliers. Unless they have done some drastic changes.
Besides which, again, unless they have made drastic changes I'm unaware of, the discs are not part of the hub assembly. Completely seperate. One reason it's such a PITA changing tires, the holes in hub and disc go out of line.
When you reassemble, the specs for older cars, at least, tell you that you should be able to move the washer under the nut with a screwdriver, just pushing, not using it as a prybar against the cap fit. Remember to spin the wheel both ways to seat the bearings as you tighten.
Cheers,
George
ades world
Mar 21, 2007 07:03 PM
wakeboarderdave
Feb 12, 2007 10:55 PM
aden478
May 22, 2006 02:49 PM
Luis
Dec 31, 2005 09:13 PM
cjard
May 24, 2005 10:26 AM
