Instrument Panel
Old Jul 29, 2007 | 03:03 PM
sdiegidio's Avatar
Default Instrument Panel
I thought that maybe my instrument cluster was bad since the odometer did not work, neither did the trip meter nor the Tach. The speedometer works fine, the fuel gauge and the temp guage are all ok including the fuel computer readout. I picked up a insturment cluster from the salvage yard but to no avail. The same things still do not work. I am guessing that there must be a few bad relays. I have no idea which ones they may be. I am unable to find a manual for this vehicle. I have an 89 Model 90 2.3L 5 cyl.
Steve
Old Jul 31, 2007 | 12:28 AM
InExile's Avatar
Default RE: Instrument Panel
electronic speedo or cable driven
Old Jul 31, 2007 | 05:28 AM
sdiegidio's Avatar
It's all electronic. there are no cables going to the panel.
Old Aug 2, 2007 | 08:49 PM
InExile's Avatar
there are solder foints on the backs of the clusters .... look at those some might be cracked .... did it stop working all togeather or does it sometimes work and most of the time not
Old Aug 2, 2007 | 08:53 PM
sdiegidio's Avatar
The Tack, Odometer and Trip have never worked. I acquired the car about 6 months ago and have brought it back from the dead. It was not running at all. I have it running fairly well, stil have some bugs in it. But ever since I have had it on the road.. Those items on the panel have never worked.
Old Aug 3, 2007 | 04:24 PM
InExile's Avatar
look at all the wire conections on teh back of the cluster ... and see if you can check the speed sender unit that is mounted to the tranny ... but deff check on the solder joints ... it is goind to be hard to see so use a magnifying glass
Old Aug 4, 2007 | 02:01 PM
sdiegidio's Avatar
The sending unit mounted to the tranny is supposed to be new, lol. Hopefully it is.. I just had the trans rebuilt. I will take apart the cluster though and check all the connections and solder joints. I have a good magnifying glass.
Old Aug 4, 2007 | 05:23 PM
InExile's Avatar
i can email you a pic of where to look .... will not be the same cluster though but it sould give you a good idea ... you can pm me your email
agmb
Aug 24, 2012 08:25 PM
bonestock3
Dec 5, 2010 04:12 PM
alberta-s4
Nov 7, 2010 06:06 PM
descarl
Feb 10, 2007 10:51 AM
AudiPOS2001
Jun 12, 2006 08:56 AM
