Remove steering wheel and cap on '83 5000 series
Old May 25, 2007 | 05:03 PM
Mecallie's Avatar
Default Remove steering wheel and cap on '83 5000 series
Hi there, I apologize for my first post being a question but I'll make it up to you
There was a short behind my steering wheel resulting in the fact that I can now only drive with my high beams on or my city lights, not with the normal low beams. Also the horn now does not work anymore. Both are not a fuse issue, I have checked. I am guessing the high beams stay on because there is a permanent contact now. Also: I found a (burnt through!) little spring when I was checking for the short.
So I decided it was time to take the steering wheel of and have a look to see what was going on behind it. I got the wheel of just fine but the cover (with the metal/plastic ring in the center) does not want to budge. I have no idea how to get it off and am afraid I will damage it if I use to much force.
Is there a screw or some kind of click mechanism that I should be aware of? Please help me get this cover off so I can replace the faulty spring and fix the low beam problem. Thanks in advance!!!!
EDIT:
Sorry about that: I am the proud owner of an '83 Audi 100 / 5000 1.9 100hp
Old May 26, 2007 | 11:03 PM
InExile's Avatar
Default RE: Remove steering wheel and cap on '83 5000 series
there is a screw .... insert screw driver from below kinda diagonaly .... it's kind of a clamp holdingit there whitch u can't see
Old May 29, 2007 | 05:09 PM
Mecallie's Avatar
Yup, that was it thanks
You just have to feel where it is and unscrew it a couple of turns. Not to much or the screw will get lost under the dash
Thanks!
Old May 29, 2007 | 08:58 PM
InExile's Avatar
glad to help
redmond1501
Nov 19, 2011 02:07 PM
Jackmup
Oct 5, 2009 11:23 PM
tnscmatt
Jul 17, 2009 04:17 PM
QuattroChucko
Dec 10, 2006 01:27 PM
