Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
1999 a4 2.8l quattro fuel problem.? Help!!
Old Jul 14, 2005 | 07:20 PM
titanmotor's Avatar
Default 1999 a4 2.8l quattro fuel problem.? Help!!
I have a4 1999 2.8l quattro . When I sstart my car in the morning in runs fine a cranks up no problem, but if I stop and go in somewhere the car will just crank but will not turnover, if I wait about 45-1hour it will start up fine. I figure something electrical is getting hot, my car has 70k on it, anyone experienced this problem, your help would be really appreciated, thanks ty
Old Jul 26, 2005 | 04:55 PM
Jestnomen's Avatar
6th Gear
Default RE: 1999 a4 2.8l quattro fuel problem.? Help!!
Have you tried starting it with the gas pedel to the floor?
Old Jul 30, 2005 | 06:53 PM
titanmotor's Avatar
HERE IS WHERE I AM I HAVE REPLACED
FUEL PUMP RELAY
FUEL PUMP
COOLANT TEMP SENSOR
SUCTION PUMP
THE CAR WILL START WHEN I PUT GAS IN CYLINDER
THE CAR IS NOT GETTING FUEL FROM INJECTORS
POSSIBLE FIXES NOT SURE BUT
THROTTLE VALVE CONTROL MODULE
FUEL PRESSURE REGULATOR
BAD INJECTORS
THROTTLE POSOTION SENSOR
ETC.
PUTTING PEDAL TO THE FLOOR DID HELP- , BUT IT STILL WOULD NOT START
ON BATTERY STARTER AND WITH BATTERY CHARGED UP.
Old Aug 3, 2005 | 12:51 PM
titanmotor's Avatar
follow up to help others, the fix was fuel pump and relay, the clogged fuel filter probably burned up the original pump, ty
Old Aug 8, 2005 | 09:25 PM
Jestnomen's Avatar
6th Gear
glad to see you got it resolved.
Bashawin
Jul 13, 2010 07:31 PM
Bashawin
Jun 24, 2010 10:53 AM
netwave
Oct 31, 2008 09:38 PM
mirak
Feb 10, 2008 03:02 PM
titanmotor
Aug 3, 2005 12:50 PM
