Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
2001 a4 help
Old Apr 17, 2012 | 05:17 PM
KarlD.'s Avatar
Default 2001 a4 help
I have 2.8 quattro. I put 20 bux of gas into the car and had a 3/4 full tank. I drive maybe 5 total miles and the needle drops to a little over half. But when i turn the car off and use it later on in the day, the needle will go back up again SOMETIMES. I know the car is a v6 but...
Old Apr 18, 2012 | 07:25 AM
jmarshall098's Avatar
Did you checked the battery level? It could be possible that the fuel meter won't be getting enough current supply to read the values correctly.
Old Apr 18, 2012 | 11:55 PM
ImTheDevil's Avatar
It's the sending unit in the tank. Either the resistive element needs cleaning or the small wire on the float arm broke and needs repair. Simple fix.
Old Apr 19, 2012 | 10:30 PM
KarlD.'s Avatar
Thank you for your contributions. My battery is producing adequate charge so i think it is the sending unit.
Wtftylor
Nov 1, 2012 01:01 PM
klipsch21
Jul 27, 2010 08:41 PM
Euthanasia
Feb 22, 2008 01:30 PM
Jorgen
Jul 29, 2006 02:25 PM
Bit646
May 11, 2006 05:24 AM
