Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
adjustable fuel pressure regulator
Old Nov 11, 2006 | 03:34 AM
hihistan's Avatar
Default adjustable fuel pressure regulator
hi all............i just bought a adjustable FPR with fuel pressre gauge with it........just wondering how much pressre should i set??
i have AMD chipped,k&n filter,performance exhasut with de-cat and spark plugs............thanks for help
Old Nov 13, 2006 | 07:10 AM
chrisaudi's Avatar
Default RE: adjustable fuel pressure regulator
4 bar
Old Dec 16, 2006 | 12:02 AM
DenimTT's Avatar
ORIGINAL: chrisaudi
4 bar
lol, not really.
You need a way to view your fuel trim as well, preferrably an EGT gauge or wideband o2 sensor. Dont just make adjustments in the dark, or even based on suggestions of others. Every motor/setup(this is why cars use adaptive ECU mapping) is unique and you run the risk of going too lean or too rich which can cause serious issues.
If you dont have a turbo/supercharger or nitrous then you can make rough adjustments with an air/fuel gauge with less risk, but dont even try it if you use any forced induction. Common A/F gauges dont have a wide enough calibration range to even view the proper mix let alone dial it in.
4 bar would be a safe setting, but its a complete waste of an adjustable FPR. Its a (commonly used) rough enrichment to make a modded car run smoother/more safely. I trust you bought a full adjustable unit for the ability to really dial in the tune, which you need more information to do.
A leaner mixture makes more power, so if you can get away with say a 3.8 or even a 3.9 bar setting youre that much better off then the run-of-the-mill 4 bar drop in regulator. Go do some research on EGT's, Wideband o2's, and air/fuel tuning and you will be way better off.
Most importantly: Dont adjust ANYTHING in the fuel system until you know what you are doing and why. The results can be catastrophic if you make a mistake.
Old Dec 16, 2006 | 09:48 PM
kakarot's Avatar
I always new, 12.5:1 is max power, 15.5:1 is max economy.
the stock is about 35psi, so thats 2.3bar of preasure..
the advantages of the user regulated fuel preasure regulator is that you can set more presicelly the actuall flow of the injectors. So that you could get 0% trim. There is no way to set the eracher or leaner, at the end if screw up you just get a CEL. Thats for OBDII, for OBDI that are like last ones, they still dont have any point. the older system, like CIS or like that, the FPR is good, couse you can actually tune the map close to what you want.
Old Jan 3, 2012 | 06:04 PM
vtraudt's Avatar
What did buy, where and what did you pay? In the business for one myself. Installed the ECS on the 1.8T (Giac PC16 call for 3.0 bar (most run even lower at 2.8 or 2.9 bar), but did not like that I had to also splice a fuel gauge in (cut rubber line, splice T in; afterwards splice the cut with 2 hose clamps and straight connector).
For my 2.7T (running 100% injector duty cycle, MAF read 280 g/sec, still stock K03), I would prefer an AFPR with gauge right on it. Until re-tune is done, I want to run a bit higher pressure to avoid lean at higher RPM.
Old Jan 3, 2012 | 07:25 PM
turbo kraut's Avatar
Tech Guru
You realize this thread is 6 yrs old and that those aren't even semi-active members?
ECS Tuning
Jan 11, 2013 03:51 PM
ECS Tuning
Jan 11, 2013 03:50 PM
machetetooth
Feb 15, 2008 11:42 PM
hihistan
Nov 11, 2006 12:29 PM
