Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Audi a3 Login codes, eeprom, skc, vag tacho
Old Sep 24, 2011 | 01:46 PM
Kardiii's Avatar
Default Audi a3 Login codes, eeprom, skc, vag tacho
Hi all!
I've bought an ebay cable for vag com 409.1 and vag tacho..
My first question do you know any working login codes for the VCDS light or vag 409.1? I mean.. i'd like to adjust something in the instrument cluster.. but i'd need to login first.. but i don't know what shoud i put in there..
And also in vag tacho when i'd like to correct the odometer (i have the marelli m73 V1 inst. cluster) when i tried to correct it in auto mode it show do it in manual.. ok..then it needs to read the pin.. the pin read is ok.. but shows can not read ping check the memory.. so i checked the eeprom memory data.. it shows a lot of rows with hex data and unknown characters.. so somewhere there i'd have to locate the hex address for the pin, and insert that into the change mileage button so it can read and rewrite the mileage using the login/pin code..
I'd really need to know which row contains the pin/login/skc because i'd like to buy a new instr. cluster and if it does not have the skc or the login code i can not adapt the keys to is..
Please some1 help me it's really important.. Oh some more info.. i have Audi A3 8l 1.6petrol 97.12.18.
Cheers,
Kardiii
PS: Sorry for duplicating but dunno what is the proper section.
Kardiii
Mar 12, 2016 07:24 AM
Cks69`
Oct 11, 2012 01:24 AM
Kardiii
Sep 24, 2011 01:45 PM
Methylester
Aug 27, 2008 12:50 AM
zingo1
Dec 5, 2006 06:28 PM
