Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Bad computer??? Anti- theft mode??
Old Dec 22, 2008 | 07:07 PM
zstone33's Avatar
Unhappy Bad computer??? Anti- theft mode??
I have a 1999 audi a4 quattro. This all started when i pulled the fuse for the engine timing while the car was running. After this the car wouldnt start. I bypassed the ignition and hotwired the car...still nothing. I located a loose ground to the starter which was arching everytime i would start the car. Tightened that up and got her to start. But after starting the car it would only go to 1500 rpm and then jump back down. A code reader i bought told me the throttle position sensor was bad...audi dealership and 2 other mechanics told me the same thing. I replaced the throttle body and i am still getting the same results. PLEASE HELP
Old Dec 24, 2008 | 05:05 PM
outlaw24's Avatar
Default need to throttle position adaptation with a vagcom
I fixed a car with the same issue. You need to re-calibrate the throttle position sensor. You will need the vag com software and cable. Instructions to do it are on the site.
Old Jan 7, 2009 | 06:21 PM
djaudisy's Avatar
sry not to be selfish but I hear that arch when I turn the ignition, do you mind mentioning where that loose ground was? hope everything works out man
quattroforthewin
Jun 18, 2010 02:14 PM
artracer
Jul 20, 2008 03:19 PM
CaRCrAzY9229
May 6, 2006 07:11 PM
sillyboy
Oct 3, 2005 11:50 PM
