Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Cheap power, Diode, MBC, and Boost gauge install
Old Jan 3, 2008 | 06:28 PM
  #121
Bondga's Avatar
Default RE: Cheap power, Diode, MBC, and Boost gauge install
No you don't need a catch can, you can put one for kicks and giggles but you'll get along fine without one
Old Jan 3, 2008 | 06:33 PM
  #122
cincyTT's Avatar
I'm make believe
you dont need one but the more pressure in the engine, the more oil that will end up in the intake. Its always a good idea to have one. Mine is basically a air compressor filter inline to the intake. You can get everything from home depot racing for about $30
$14 for the filter
$12 for the fittings (1/4" to 1/2")
$6-10 for hose
BTW, those pics were in my gallery and got deleted for space
Old Feb 7, 2008 | 06:13 PM
  #123
Dirty's Avatar
Would an EBC work just the same, or do you recommend using a MBC?
Old Feb 8, 2008 | 06:08 AM
  #124
sdboarder84's Avatar
EBC's are the best. Go with an Apexi AVCR they have the most features and you will be able to get the most outof a stock turbo.
Old Feb 8, 2008 | 01:22 PM
  #125
cbehr's Avatar
I don't mean this to sound offensive, but if this mod is so cheap and just as effective/safe/reliable as a chip....why are people still paying $500 to get their ecu flashed? I'm assuming most just don't know about this or don't trust it?
Old Feb 8, 2008 | 02:33 PM
  #126
cincyTT's Avatar
I'm make believe
not everyone can use it, trust it, or install it. A chip is still the best way to make power and reliably. This is just a cheap thing to do until you go that route or bigger
Old Feb 8, 2008 | 03:12 PM
  #127
cbehr's Avatar
So I guess what your really saying is if I got the $500 to spend I should go the chip/flash route unless I plan on going BT in the future.
Old Feb 8, 2008 | 04:01 PM
  #128
Bondga's Avatar
this has few more limitations than a chip. it will not make as much power as a chip because you cannot alter your redline. Also (though some say you don't have to) you need to increase the amount of fuel you inject and advance your timming for best results. The reason people still pay for a chip is the same reason people still pay people to change there oil.
Old Feb 8, 2008 | 05:46 PM
  #129
cincyTT's Avatar
I'm make believe
the power dies past 5500rpms. Why would you need to increase the revs past 6800? Your making about 30-40hp less there than 5500rpms.
Old Mar 16, 2008 | 10:40 PM
  #130
brmiddle's Avatar
do a little research on the early chrysler omni/daytona/laser cars. this was one of the first things you would do to the 2.2 turbos. MBC and a zener diode would drop minimum of a second in the quarter.
