Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Cheap power, Diode, MBC, and Boost gauge install
Old Jul 26, 2007 | 11:43 PM
  #31
vassar007's Avatar
Default RE: Cheap power, Diode, MBC, and Boost gauge install
Which boost controller do you recommend Cincy?
Old Jul 26, 2007 | 11:45 PM
  #32
cincyTT's Avatar
I'm make believe
bleed/gated valve will be the smoothest. A combonation ball and spring w/ a bleed valve is a little more but well worth it fora mbc (what i use, turboXS hpbc)
Old Jul 27, 2007 | 12:02 AM
  #33
sean1.8t's Avatar
ORIGINAL: vassar007
please do something other than just slap on a mbc with you chip. if you up the boost like 1 maybe 2 pounds your ecu should be able to compensate for that. but the APR software is not as easily tweakable as other tuner's like GIAC. try to moniter air/fuel ratio. be it installing a wideband, or logging fuel trims with VAG-COM. lemmiwinks is your friend!
Old Jul 27, 2007 | 12:22 AM
  #34
cincyTT's Avatar
I'm make believe
Dont know why you say that. The car can easily compinsate fueling with a chip and 18-22psi.
Old Jul 27, 2007 | 12:25 AM
  #35
sean1.8t's Avatar
and you know this because you have a chip??
ya, didn't think so..
but maybe you want to pull up some 3 year old Vortex threads where a Volkswagen's APR'd ecu did compensate for it.. be my guest
Old Jul 27, 2007 | 12:28 AM
  #36
sean1.8t's Avatar
in fact, i know specifically of a kid with a 2001 1.8t with GIAC ko3 software. he is running at 22psi(don't ask me why) with mbc AND diode mod.
most inportant part is that he has a Zeitonex-sp?- wideband and made a couple fueling tweaks with lemmiwinks
Old Jul 27, 2007 | 12:30 AM
  #37
cincyTT's Avatar
I'm make believe
so is this that part wherei cry and report you to a mod and have your post deleted?
Old Jul 27, 2007 | 12:32 AM
  #38
cincyTT's Avatar
I'm make believe
The ecu will compensate fuel trims withen a spec range. Your friend used a 4.7v diode and limited boost seen by the ecu to 17psi and then ran 5additional psi.
Mine has compensated seeing 11psi and running 19-20psi with no fueling problems whatsoever
Old Jul 27, 2007 | 12:36 AM
  #39
sean1.8t's Avatar
if you and the mod feel that, that would be the best solution and best benefit for the thread and it's purposes. then yes, by all means..
this guy's car definately isn't going to blow, im just trying to get this guys carto run tip top to it's potential.not justsub par like imsure yours is running..
it's best to educate the noobs the best way possible as soon as possible. otherwise there is going to be that one idiot that's going to put aBT on his car and say, "i can probably just use the diode modew/ stock injectors and turn the boost up to 22psi" then KABOOM!!!! [/exaggerated example]
Old Jul 27, 2007 | 12:44 AM
  #40
cincyTT's Avatar
I'm make believe
Well since i said in the first post that it should be limited to 16-18psi, i would hope that people would take that into consideration. But you and i both know you cant fix stupid.
A/F should always be monitored when doing anything major to your car, and yes i think something like this is major. For those that dont have access to a vag cable should still know that they are in a safe range and shouldnt fear about causing harm to there engine.
You and your boy Karl act like its going to blow in the matter of mins. As i stated in my original thread, this is/was a temp solution until i replace my BT setup.
