Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Cheap power, Diode, MBC, and Boost gauge install
Old Aug 28, 2007 | 07:11 PM
  #81
pyongwonse's Avatar
Default RE: Cheap power, Diode, MBC, and Boost gauge install
Bondga, what are you using lemmiwinks for?
Old Aug 28, 2007 | 07:23 PM
  #82
cincyTT's Avatar
I'm make believe
You MUST gap them to .028 regardless of heat range. He usues it to add fuel under boost with lemmi.
Old Aug 28, 2007 | 10:24 PM
  #83
Bondga's Avatar
i use lemmi to adjust my ignition timming, Lambda regulation, Idle torque, rpms at idle, and tweak the fuel a little bit
Old Sep 5, 2007 | 03:47 PM
  #84
david_328's Avatar
and what is a good place to buy these parts??
Old Sep 5, 2007 | 04:04 PM
  #85
cincyTT's Avatar
I'm make believe
diodes are easy to find on ebay andthen itdepends on the gauge you want and mbc.
Old Sep 5, 2007 | 05:19 PM
  #86
david_328's Avatar
what do u recomend??? i have a 2000 a4 1.8t im new at this as u can c.. i was in the honda/acura family so big difference.. and all the help i can get i thank u... also i need to change the gaskets from the engine to the manifull... where should i get this and is it easy to do???
Old Sep 13, 2007 | 11:14 AM
  #87
greene08's Avatar
I like chips... they control and monitor much more than just the boost.
Old Sep 13, 2007 | 11:19 AM
  #88
Bondga's Avatar
I'd rather do it myself then pay someone to tune my car. you can control monitor and more with the diode mod(lemmi+vag/ecu explorer). it all depends on how willing you are to spend the time.
Old Sep 13, 2007 | 11:27 AM
  #89
onepoint8tee's Avatar
Youre probably not getting as much power from the diode mod as you do with a chip. You cant tweak fuel mapping with lemi, and thats one of the most important things in a tune. I know the ecu will adapt somewhat, andyou can enrich fuel under load/at idle and a couple other cool things to the stock fuel maps, but you arent getting as aggressive performance thata real ecu tune gives. But for a 20 cent diode and a little elbow grease, Im sure the gains are worthwhile when compared to the cost.
Old Sep 13, 2007 | 12:38 PM
  #90
whodatt1's Avatar
Great easy hp increase.. very interested in doing this (similar to how we fool the MAP sensor when turboing the 420a in the eclipse) however I was wondering if anyone has A/F numbers on an A4. Timing and fuel pressure would be awesome to see as well if anyone has that. I have read through the thread and the the link to the VWvortex site, and no one has posted comoforting numbers for timing, A/F and FP. The A/F readings for the guy in the VWvortex thread are a bit scary..
[align=left] [/align]
