Fuel injection cleaner
It depends on how much sea foam you used. I read a few posts that tell you to use the entire can but I'm a bit wary of that and it opted for the sea foam procedure that involved injecting it into the intake manifold via a vacuum line as opposed to dumping an entire can of it into the gas tank.
Now one thing you didn't mention is wether or not you used the seafoam with a FULL tank of gas or not. If you did it with a half full tank then I'm not surprised the engine was stalling. It's been awhile, how is she running now?
Modern gasolines (since the 90's) have all been reformulated with more detergents and they burn cleaner than gasoline did in the 60's. Any of the "top tier" association's gasolines should be just fine without additives. If you want a little assurance, there's always Chevron's Techron, which is supposed to be the same detergents that they put in their (top tier) gasoline. A bottle every year can't hurt, except your wallet, but these days gasoline doesn't clog anything the way it did even in the 70's. Unless you're using real cheap gas and putting on really high miles.
Hockeymonkey
B7 Models
Mar 17, 2010 11:56 PM
