Black smoke and Diesel Injection Cleaner Additive
Old Oct 8, 2009 | 09:14 AM
Grapeel01's Avatar
Default Black smoke and Diesel Injection Cleaner Additive
My TDi 1.9 A4 puffs a bit of sooty black smoke from the exhaust usually at gear change. To be fair I think it has done this for quite a few years but a mate drove it last night and as I was following in my work car I noticed it - now it is dwelling on me as I have the yearly car check coming up in early Nov.
One of the testers a few years back said I should rev the engine a few times immediately prior to the emissions test just to 'clear it out', someone else stated to use a fuel additive as to clean the injectors, another said drop in some petrol to 'burn off' any deposits.
As many of you work for Audi I would appreciate your comments/thoughts and advice. I should add that the fuel and air filters were changed by Audi very recently as part of service regime.
Old Oct 8, 2009 | 03:12 PM
ghost6303's Avatar
never put regular petrol in a diesel engine.
im not too familiar with the TDIs in particular but with any car you should drive 'spiritedly' every once in a while, wind it up to the redline a few times. that works better then just reving it. if there is no other problems, i really wouldnt worry about it that much.
Old Oct 9, 2009 | 01:47 AM
Grapeel01's Avatar
Thanks Ghost, appreciate it. There are no other problems - car is great.
I am in Sweden and one can get banned for being 20% over the speed limit. Say for instance doing 40 in a 30 limit will earn a few months public transport time! So I have learnt to drive like an one armed granny - probably causing that build up of soot.
Any thoughts on the additives?
Old Oct 9, 2009 | 01:59 AM
A4Cragman's Avatar
Additives generally do what they're supposed to so you should be safe to use those. If you have access to seafoam there, I would recommend trying a full treatment and see if that helps any.
audimauler
Dec 7, 2013 05:50 PM
kenman
Jun 5, 2013 11:46 AM
newaisa
Oct 4, 2010 10:22 AM
Armenian
Jul 22, 2008 06:04 PM
modset
Mar 31, 2007 07:27 PM
