How to replace a fuel pump
try googling it.. if you cant find anything in the a8 section here then idk...
pretty straight forward though, just have to figure out where the pump is on an a8 which i dont know.. take out old/bad one, and hook new one up the same way you took the old one off
Has anyone ever seen this knife before and can it really be used on a bayonet? It is said that it can fit together with a AK47 rifle. Maybe it is a copy of some old military knife that was used back in one of the wars? The website that it is on is www.lducompany.com I am wondering if it can fit on any other types of guns or rifles. Does it look like something that would be used by Chinese, Koreans, or Russians. Here is a link to the knives page http://www.liangdianup.com/knives_1.htm and it is the knife with the number 406023 right at the top of the page.Any help would be appreciated before I order it all the way from China
I guess Lyly can't figure out what form they are in.
willbert7 you should be able to access the fuel pump through a hole in the floor pan under the rear seat...it is inside the tank.
Is you pump dead or are you getting low pressure? It could just be your fuel filter. This is located in front of the rear passenger side wheel. It is external to the tank.
skihigh2299
Oct 11, 2015 05:54 PM
jsethwerner225
Nov 14, 2014 01:55 PM
