Cleaning Wheels
Old Jun 19, 2005 | 12:52 AM
Karl's Avatar
Default Cleaning Wheels
Hi I am curious what you guys recommend for cleaning my stock wheels on my 96 A4... they are getting quite dirty and need something more than soap and water thanks!!
Old Jun 19, 2005 | 02:49 PM
TOGWT's Avatar
Default RE: Cleaning Wheels
Cleaning Clear Coated Wheels:
•Ensure wheels and rotors are cool before applying cold water as this may cause them to warp. Hose off as much initial grime as you can. Rinse up into the wheel well to wash away road kill, mud and other debris.
•Use detailing clay to remove any imbedded contaminants
•Use a solvent based cleaner to remove any road tar
•Apply a solution of P21S Total Auto Wash to wheel-wells and tyres, and let soak in, agitate with a long-handled boars haired brush before rinsing
•Spray P21S Wheel Cleaner, this cleaner is 100% acid-free and will not damage any type of wheel finish. (Gel for badly soiled and regular for normal soil) onto wheel rims and lat soak in.
•Before finally removing cleaner, agitate with a soft brush and then rinse off
•Rinse wheel surface thoroughly with clean water (to avoid splashing paint surface rise by pouring a bucket of water over each wheel from the top down
•Remove any surface imperfections with a suitable clear coat polish (dependant upon extent of damage)
•Dry wheels with a towel, apply a polymer sealant (Klasse AIO or ZoopSeal) to the surface of the wheels, it will protect the finish from brake dust and the elements and also make them easier to keep clean.
•Wax has a low melting point and will not withstand the sustained temperature
JonM
Old Jun 19, 2005 | 07:58 PM
Karl's Avatar
wow. thanks!
Old Jun 20, 2005 | 10:51 AM
Danase's Avatar
I am a huge fan of Four Star Wheel Cleaner Gel.
MeanAudiA6
Mar 24, 2011 08:05 PM
beerghost
Oct 11, 2009 08:05 PM
Schwalbe181
Jan 29, 2009 05:54 PM
JDAslin81
May 17, 2008 01:13 AM
Mya4T
Nov 5, 2007 03:40 PM
