How to get my paint like new
I own an 2001 audi a4 brilliant black.
The previous owner lived in washington(rain) and it was a woman who didnt really care.
So i have swirl marks everywhere and little like dried water spots on the windows. What are the steps and supplies to get my paint like it was new, smooth and shiny. Im trying to keep this a low cost situation.
So like give me some steps (do i need a spinny buffer thing) and what to buy. Also, on the back i have big, way less shiny marks, from where i debadged and used a brush, then tried to 3m rubbing compound. how can i fix those, and the water marks.
I want to get the car all nice, then put something on it to keep it that way, so that all i have to do is wash with some soap and water and maybe spray some "instant detailer on" just need an idea from worst to best steps. low cost
Thanks guys..
Thanks guys..
Where is WA are you? If you are local, I have everything you need at my house.
Black is the most PITA car to look nice, but when done right, looks HOT!
Chances are you will need a multi step detail, that should take the better part of a day.
if you have a DA buffer like a PC or a UDM (only way i can help, only way i know how)
Products needed
clay kit
Adjustable speed DA buffer
2 finishing pads, 1 med cut pad, 1 heavy cut pad
polishes of your choice
wax
glaze
sealent
Start with a clay kit. then a final/intensive polish (always start less agressive and work your way up) then if there are still some small scraches add some glaze if not go right to the sealent. i recommend FMJ, apply it evenly and let it cure for about 20-25 min OUT of the sun. after the sealent add as many coats of wax as you choose.
Products needed
clay kit
wax
glaze
sealent
I'm bringing this post back from the dead because I own a 2001 a6 in brilliant black. Any more advice on refreshing paint and polishing? I have less of a budget constraint because I want it done right, looking fresh.
Step 1 -Wash
Washing your car is the most important part of keeping a swirl free ride. Sadly, this is the stage where the majority of the swirls are actually created due to improper washing techniques. I will explain how to properly Wash a vehicle.
What you need:
2 5Gallon buckets
2 Grit Guards
A Good Shampoo (Megs Gold Class, Adams, Chemical Guys Citrus Wash etc...)
Microfibre Washmitt (alternatively you can use lambswool, or Schmitt)
Waffleweave drying towels (these are 100% cotton drying towels that absorb water)
Process:
Rinse the vehicle with a pressure washer and always work from top to bottom.
Once rinsed fill 1 bucket with warm water and the other bucket with soap. Ensure the grit guards are in place.
Using the washmitt start at the top and dip the wash mitt in the soapy water and then onto the car.
Then rinse the wash mitt in the water only bucket to get rid of all trapped debris.
Dip again in soapy water and continue until the whole car has been washed. Do not let the soap dry.
Rinse off and then use the WW Drying Towels to dry the vehicle.
The above washing method is basic. If your car is really dirty I recommend foaming the car first with a foam gun before using the shampoo. Also the wheels and arches should be done first before the paint. A cost effective method to do the wheels is to use a strong All Purpose Cleaner (APC) like Zep's industrial strength or Zep Citrus and diulte 4:1 with water.
To get rid of bugs and tar you can use APC (diluted 4:1 or stronger if needed) and spray over contaminated area. Agitate with soft bristle brush or boars hair brush.
Step 2: Clay
A vehicle is clayed to remove surface imperfections that washing can not remove such as dirt trapped within the paint. Such dirt and debris consists of rail dust, brake dust, overspray, tree sap etc...
What you need:
Clay
Clay Lube
Process:
Spray the area with the clay lube and in a back and forth motion use the kneaded clay to rub the surface. Make sure the surface is not hot otherwise clay will marr the area.
-use adequate lube and knead the clay once the surface becomes dirty and repeat until the whole car is clayed. Your shoulders will be sore and it takes about 45min to do a small to mid-size car. Do not use water as lube because water does not provide the same lubricity as some of the lubes on the market.
Claying the surface will also leave your car smooth and glass-like to the touch. A vehicle should be clayed 1 to 2 times per year.
Step 3- Correction/Polishing
This step is optional and it depends on your vehicles condition. If your vehicle has swirl marks and other paint defects such as holograms, buffer trails, and overspray then follow the correction process.
Now this can get complicated and there are hundreds of different methods out there so I will keep it as simple as possible and targeting this to newbies.
What you need:
PC 7424XP
Cutting Pad
Polishing Pad
Finishing Pad
Compound
Polish
Finishing Polish
Now I haven't given any product references because there are literally hundreds of different brands out there so choose whatever you like. For newbies I have seen the Adams line do wonders because it's very easy to use. Here's a link to a package.
Ideally you want to use the least abrasive combination first to remove the imperfections and if that doesn't work you step up a notch. The reason being you want to remove as little clearcoat as possible. Yes, polishing removes clearcoat. But before you get your panties in a knot just know that it is very little. Infact most swirl marks and scratches range from 2-5 microns. 1 micron = 1/1000 of a millimeter. An average car contains about 80-120 microns of clearcoat.
Step 4 - Last Step Process
Applying a LSP is key. I recommend appyling a Sealant and then a wax.
Sealant - Acts as a layer of glass and gives the car a wet look while protecting it from UV Rays, acid rain, and other elements
Wax - use a Carnauba wax. The higher the content of Carnauba the better. Some of the higher end waxes contain a Carnauba content greater than 50%. Carnauba is a natural wax that comes from Brazil. It has natural waterproof capabilities and also adds a level of depth and lustre to vehicles. Carnauba waxes can range anywhere from $40 to $20 000 for a small container.
Once the car is fully prepped a sealant is applied and allowed to cure on the paint. Once the sealant is buffed off the wax can be applied and layered as the owner pleases. Some good sealants are....Duragloss 105, Chemical Guys Jetseal 109, Opti-seal, Werkstat Jett Acrylic etc....
Some good waxes are...Chemical Guys 5050, Pinnacle Souveran, Lusso Oro, Dodo Juice Supernatural, Wolfgang Fuzion, Swissvax, Zymol.
And that's a GENERAL gist of cleaning a vehicle. Once a vehicle is clean it is proper washing techniques and care that dictates the longevity of the paint's flawless finish. A car that constantly gets abused by squeegees, brushes, and other harsh conditions will obviously have a dull finish.
The above was written for the newbies and as an introduction to detailing. It is a very basic tutorial and if you follow those simple wash steps above you should have a good finish no matter what.
Hope that helps,
-Waseem
