remove the swirls from your black paint
just thought i would share a secert in removing swirls in black paint the was passed on to me.
our "master detailer" at the dealership turned me on the some stuff called Ardex Seal B
[IMG]local://upfiles/5206/C2A6DFEDD13146B0A9B1F6C25B5D4F8A.jpg[/IMG]
it does a beautiful job of making those pesky swirlys go away. use it with a foam pad on a high speed buffer.
the great part is this stuff stays wet under the buffer head for a long time, unlike other polish that drys before your done working
over a area.
i am not sure where you might be able to find this stuff in your area but i seems to be very popular with high end body shops.
over a area.
ORIGINAL: headshok2002
When the product dries, that is when it is doing the cutting... when its wet, its just spreading around the surface. You want it to dry, as you cut... thats how it works.
Also, is this product removing swirls or filling them? Lastly are they buffer swirls or marring that you are seeking to get rid of? Buffer swirls are micro-scratches caused by a high speed rotary, a coarse pad and aggressive product. They take on the look of a 3D hologram within the paint, as if it is a flowing ribbon.
Marring or halo-scratches on the other hand are introduced into your paint from washing and drying. They are tiny, very fine scratches that take on a circular appearance as they catch the sunlight.
Knowing what you have helps in knowing how to correct, not hide, the paint problem.
Anthony
