DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
How to replace your thermostat (AEB)
Old Apr 28, 2008 | 07:32 PM
chaos92287's Avatar
Default How to replace your thermostat (AEB)
Difficulty- 2
Tools Needed
[ul][*]6mm allen wrench/socket[*]13mm socket[*]10mm socket[*]Socket wrench[/ul]
The thermostat is on the bottom drivers side of the engine, just behind the water pump, which is number 4 in this diagram
So jack up your car and remove the belly pan if you still have it.
Now drain the coolant through the drain plug on the bottom driver's side of the radiator. There should be a red or black plug with a + sign on it. If your not changing your fluid, just drain it into a container and pour it back in after your finished.
Here's a pic of what its actually gona look like. For reference, that is the oil drain plug in the bottom right of the pic.
Now that the bracket is out of your way, you can remove the two bolts and take the thermostat cover off. Then just swap out the thermostat and o-ring and put everything back together reverse of how you took it off and refill your coolant.
Afunk
Mar 11, 2013 10:45 AM
jonthee
May 18, 2012 02:56 AM
chaos92287
Apr 28, 2008 07:32 PM
vwwife
Oct 7, 2007 10:52 PM
johnny5
Apr 18, 2005 09:46 AM
