01 S4 double din install with metra bose harness troubles!!!
Old Feb 21, 2010 | 07:19 PM
Boostin117's Avatar
Default 01 S4 double din install with metra bose harness troubles!!!
I have tried everything hooking up this receiver. I cant get the memory wire to a constant power supply so every time i shut off the car it resets and i lose all my settings. Anyone have a fix for this??
Old Feb 21, 2010 | 08:37 PM
02A6Beau's Avatar
Run a tap off something that is always on at the fuse box?
Old Feb 21, 2010 | 11:00 PM
Boostin117's Avatar
Well i have my radar detector hooked up to the acc relay already. Would i be able to use any others??
Old Feb 22, 2010 | 09:25 AM
02A6Beau's Avatar
The memory wire shouldn't be a very big draw on the electrical system.
Old Feb 28, 2010 | 01:03 PM
Audiophyle's Avatar
The memory wire not only retains memory, it is the primary power source for the HUs internal amplifier & components.
There is a constant power (memory) in the oem harness at the radio.
There should be a somewhat large gauge red/blue (red with a blue stripe) wire in one of the black oem wiring harness, that is the memory wire you want to use.
cspaulding
Sep 18, 2011 08:02 AM
kduznetsov
Jul 16, 2011 02:54 PM
picco97
Apr 2, 2009 07:47 AM
rummy
Dec 31, 2006 09:13 PM
