2009 A6 MMI- dvd won't eject
Old Aug 30, 2014 | 05:36 PM
dschwartz2's Avatar
Default 2009 A6 MMI- dvd won't eject
I bought an update DVD from a poster on this board. However, the existing DVD doesn't eject when I push the "eject" button. Tried it with the nav running, with audio running, and with MMI off- all no good. I assume that there IS a dvd in there as the nav doesn't work without it (nav is working fine, just want the updated map)? In any case, I tried to gently load the new DVD and it wouldn't go in. Any ideas?
Dave
Old Aug 31, 2014 | 08:29 PM
aspen79's Avatar
Most likely the eject button is "locked" (electronically). It has to be unlocked (or enabled) with a scanner. Not sure if a Vag-Com will do it or you need the scanner at a dealer.
The eject button is supposed to be unlocked during the PDI process. It's basically like that so the DVD doesn't mysteriously go missing between the factory and the dealership.
Yes, if the nav system works, there is a DVD in there.
Lazydog
Jul 16, 2013 02:52 PM
Redstorm_UK
Apr 1, 2013 02:01 PM
gbkyle
May 31, 2009 08:47 PM
lespaul2510
Nov 4, 2008 05:12 PM
audifan1
Oct 3, 2007 11:35 AM
