Advice Needed: '06 A4 Factory Sound System Upgrade
Old Jun 6, 2006 | 01:25 PM
Srgtfury's Avatar
Default Advice Needed: '06 A4 Factory Sound System Upgrade
I am looking at upgrading the factory sound system in an "06 A4 that has Nav & Tech packages. I have an Alpine 350 watt mono power amp and a 12" sub in a box enclosure that can be moved to the A4.
Now, reading about ohm mismatch in the "bose" speakers (the A4 does not have the $1,000.00 Bose upgrade), I am a bit confused on what can be done to upgrade and not require major surgery. I would like to stay in the 1K budget that the Bose system would have cost and hopefully get a bit better quality.
Thank you very much
Fury
Old Jun 6, 2006 | 01:30 PM
techbod's Avatar
Default RE: Advice Needed: '06 A4 Factory Sound System Upgrade
with that kind of cash I would consider fitting a total new system
Old Jun 6, 2006 | 01:49 PM
Srgtfury's Avatar
The thing is that I want to retain Nav and Bluetooth, as factory options. Any advice on what would be compatible upgrades in that case?
Thank you very much
Fury
Old Jun 12, 2006 | 05:41 AM
bud15637's Avatar
here is what to do man go to wal-mart buy the schosce converter for like 18 bucks tap into your factory speaker wires but do nut cu, use quick taps you can get them in the automotive section too and buy an amp wiring kit that will solve all your problems and ?s call me up if i dont answer leave me a message and ill call you back make sure to tell me your number in the message
724-787-9997
truongp92
Audi Q5
May 4, 2013 09:46 PM
Iadejusto
Dec 19, 2012 05:41 AM
ss_blake
Aug 20, 2011 02:30 AM
mitch's sline
B7 Models
Sep 26, 2008 12:08 AM
Audi B5
Dec 28, 2007 11:48 AM
