fog lights on 1997 a4
Old Aug 4, 2009 | 11:17 PM
tware4021's Avatar
Default fog lights on 1997 a4
i just bought oem fog lights for the front bumber grill and i was wondering on how to wire them to a switch and if they would look good they dealership said that they will fit but they didnt know how they would wire it... i need help thanks
Old Aug 4, 2009 | 11:56 PM
ImTheDevil's Avatar
Look at the headlight wiring harnesses that connect to the rear of your headlights. You have factory foglights (they're built into the headlight assemblies) and you have a switch on the dash for them. The trigger wire for those lights is the yellow/green one in the bunch. Use a wiretap and tap into that wire, run a new wire from the tap down to one prong on the new foglight, and ground the other prong. Remove the fog bulbs from the headlight housings (bottom center bulbs), and when you turn on the OEM switch on the center dash, you'll light up the new fogs. You'll need to do this on each side.
Bring the car down to Binghamton sometime - it's only an hour's drive. We can hook you up easily here - there's a bunch of us that work together on the cars.
Old Aug 7, 2009 | 03:38 PM
tware4021's Avatar
How much would you charge me to do both fog lights if i came down to Binghamton from Syracuse?
Old Aug 7, 2009 | 04:26 PM
ImTheDevil's Avatar
Sent you a PM.
Old Aug 13, 2009 | 07:08 AM
samsyabi's Avatar
How much it cost to you? Did you get them installed?
Old Aug 13, 2009 | 09:13 AM
ImTheDevil's Avatar
They haven't arrived yet - we will install in a couple weeks when they get here.
Akenny96
Nov 29, 2014 01:23 PM
nize
Jun 21, 2013 01:16 PM
edgepro
Aug 24, 2008 09:40 AM
mschwister12
Feb 7, 2008 04:14 PM
