Fog lights - Park Only
Old Sep 12, 2008 | 07:16 PM
TinMan.KC's Avatar
Default Fog lights - Park Only
I have an '08 A4 cab.. In the manual, it shows where the Fog Lights can be in the "ON" position when the headlight switch is in the "parking light-ON" position.. Mine only work when the switch is set to the "headlight" position... If you turn the fogs on while in park, they try to come on but then shut off..
Any suggestions? I would imagine for Euro use the fogs can be set to on when the switch is in the parking lights (city0 on position.
TIA
TinMan.
Old Oct 12, 2008 | 03:17 PM
JBuD4Stasis's Avatar
Hopefully this will help, I have an 07 a4 sedan.... if you turn the switch all the way to the right and pull it out 1 or 2 clicks the fogs turn on...
Old Oct 17, 2008 | 11:21 AM
DillonC's Avatar
i have this same problem with my 02. the switch indicates there on but they only work in the headlight on mode
Paul.Chevrette
Mar 24, 2013 10:53 AM
Havyk
Sep 28, 2011 07:00 PM
MarcusV
Oct 2, 2008 07:09 AM
dtkelley2005
Sep 25, 2007 12:22 AM
RichardB
Mar 29, 2007 04:03 PM
