Headlights must be ON! How???
Old Dec 26, 2004 | 07:58 PM
powerboat's Avatar
Default Headlights must be ON! How???
I imported an A6 Q 2.8L 1999 from USA to Canada.
I must modify it, so the headlights will be on, when ignition is On according local regulations.
Does anyone know how to modify the wirirng?
Thank you and Merry Christmas.
Old Dec 27, 2004 | 01:33 AM
Jestnomen's Avatar
6th Gear
Default RE: Headlights must be ON! How???
you could probably tap into an ignition sourced 12V source in the fuse panel. Use a voltmeter to find a source that is active only when the ignition is on, then route the power line through the firewall (ECU wire bundle is a nice spot).
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
ashulga
May 7, 2010 02:56 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
