how to sound dampen the rear deck?
Old Jun 18, 2006 | 11:28 PM
Silver98A4's Avatar
Default how to sound dampen the rear deck?
With my bose system and my 2 12" sub...my rear deck is rattling and killing my sound quality. Has anyone on here sound dampened the rear deck of an A4? Could you tell me what you used and how you installed it?
Old Jun 19, 2006 | 04:09 PM
TKneedsS4's Avatar
Default RE: how to sound dampen the rear deck?
Dynamat you can by sheet of it or get the speaker sheets made to go between your car and the speaker. The stuff is quite heavy tho so if your into your performance i would reccomend using very little or just try to pull the rear deck off and fix your rattling areas with pieces of foam from a crafts store.
Old Jun 19, 2006 | 05:28 PM
evl6096's Avatar
dynamat makes a spray that works well also. I havent used it on my rear deck because i got sold a USED can and ran out before i got that far. ********. but at any rate, i was told it should work good there, but i think im going to get some foam and try that first since a can runs a lil over $20 and the actual dynamat pads run at about $60
my FRONT deck is starting to rattle just as much as the back...hah...i duno what the hell im going to do about that!
Old Jun 19, 2006 | 06:41 PM
Worlddre's Avatar
anyone purchasing deadener should read this before they purchase anything
http://www.sounddeadenershowdown.com/
HeyCesar
Feb 7, 2013 03:51 PM
rhohmann
Feb 24, 2011 11:37 AM
trampledfoot
Nov 15, 2008 04:23 AM
joel929
Sep 30, 2007 05:51 PM
randomtask37
Aug 13, 2006 11:12 PM
