Instrument Cluster brightness
Old 10-15-2008, 07:37 AM
doregan's Avatar
Default Instrument Cluster brightness
Wondering if anyone has any suggestions before I hand the car over to a garage.
The instrument panel on my A4 (1998) isn't as bright as it should be, and occaisionally flickers up to normal brightness while driving.
I can't find anywhere to control the brightness, and the fuses look OK.
Many Thanks
Old 10-15-2008, 01:24 PM
TiredOldMan's Avatar
its probably dusty in there behind the instrument gauge faces. dust accumulates on the bulb's surface as well as the instrument dials and panel insides. You could try and remove the instrument panel and using a small vacuum, clean it out. While you're at it, you could probably replace the bulbs as well. New bulbs will always shine brighter than similar spec'd old ones.
Old 10-20-2008, 08:10 AM
Bad Justin's Avatar
turn the stick right by the trip odometer? At least that's what does it on an A6.
LsJuan25
03-04-2011 10:09 AM
asutherland
01-22-2010 09:58 AM
01A6Turbo
03-22-2009 11:41 AM
jws350
08-01-2006 11:21 PM
Kid Zelda
04-07-2006 01:00 AM
Quick Reply: Instrument Cluster brightness
