Need a replacement radio (with USB) for my '04 A4
Old Sep 20, 2012 | 11:10 AM
dasfonzie's Avatar
Default Need a replacement radio (with USB) for my '04 A4
The previous owner of my car (2004 A4 Quattro with the symphony cassette/6 disc changer) damaged the lcd screen on the radio to where it's mostly blotched out. I'm looking for something that I can replace the stock radio with something with a USB port to listen to the music on my phone/internet radio, as well as hopefully keeping the 6 disc changer, although that is not a hugely important part. Mostly I just want to be able to read the screen and use usb devices.
Would anyone be kind enough to point me towards a product like this? I have used google but found a confusing list of aftermarket systems, that i'm not sure fit my car/needs
Thanks! and it feels good to be in the Audi fam
Old Sep 22, 2012 | 02:54 AM
Deusle's Avatar
I did all the stereo work in my 04 A4..
Had the stock Symphony II (iirc)
I must warn you, if you're debating on tackling this yourself, it's quite the headache at first but definitely worth the time & effort.
First, I suggest you start with an:
A4 B6 Single Din Dash Kit
Next step is deciding on the aftermarket cd player you'd like.
I recommend Pioneer for a budget install.
Just make sure the CD player has an AUX input on the face of it.
--> I'd recommend this one for you <--
It has the 3 High Voltage Preouts (RCA outputs) that you need to install a sub in your car.
Any other questions, just ask.
Here's my dash:
Eclipse AVN 6600
Attached Thumbnails Need a replacement radio (with USB) for my '04 A4-aud-b4-rad.jpg   Need a replacement radio (with USB) for my '04 A4-aud-eclipse.jpg
Old Oct 3, 2012 | 12:55 PM
dasfonzie's Avatar
thank you friend! once i collect enough money your information shall be put to use.
Old Oct 30, 2012 | 05:20 PM
rdltmc3's Avatar
Hijack.....
ive installed 100's of radios in my time but never on an audi, is this jsut as simple as a plug and play like everyother car or does it need to go through the VAG system?
Old Oct 31, 2012 | 07:56 AM
Deusle's Avatar
It "should" be plug and play as long as you get the correct wiring harness...
No need to mess with the VAG.
Research the Audi and find out if a Symphony/Bose amp is in the back (Normally behind trim in trunk; above rear passenger wheel well... at least that's where my Symphony II amp is)
I hope this steers you in the right direction.
jfoote
Apr 17, 2010 09:48 PM
vtdw
Feb 21, 2009 03:55 PM
hahaha251251
Apr 30, 2008 03:48 PM
01A4newb
Mar 13, 2008 11:24 PM
jake123
Aug 24, 2007 05:30 PM
