Radio
Sounds like you both might have a short on the motherboard. Do you hear anything coming from the speakers? Is it when you hit a bump in the road or is is just happening at different times?
Josh A.
Tech/Sales Lead
Original Car Audio
Josh A.
Tech/Sales Lead
Original Car Audio
Yea you might just have a bad CD mechanism inside of the unit. Or if everything seems to be working on the unit and you most likely have a BOSE sound system, It could be the amplifier. Do you know what the part number is to your radio?
After the car shut down, I found out that a brand new battery that was purchased 10 days ago was done. Done because it looks as if the alternator was done and running on just the battery. The car completely went into EPC mode. after a quick panic, I was told to check the battery. Car started but radio did not come on. I was also told that the system starts shutting down electrical outlets to conserve. Im thinking it is the alternator. I will let you guys know.
