Replacing RNS-E with Symphony II+
Old May 21, 2012 | 09:20 AM
4plaay's Avatar
Default Replacing RNS-E with Symphony II+
The stereo in my 05.5 was originally an RNS-E but the PO replaced it with a Symphony II+. Everything works fine except that it doesn't get good radio reception at all. I've double checked that the antenna is plugged in and it is. Does anyone have some insight as to what may be causing my issues here?
Old May 21, 2012 | 05:22 PM
pa4ul's Avatar
check the rear antenna and see if you have a crack near where the plugs are. Drivers side iirc. That will be the best bet for poor radio reception.
Old May 23, 2012 | 03:01 PM
4plaay's Avatar
I'm not seeing any cracking however I may not be looking at the right part. Am I looking for cracking at the connector, on the roof antenna, the wire, ???
Amped1
Sep 8, 2011 10:03 AM
samgamgee
Jan 28, 2011 05:20 AM
daveaz
Jan 30, 2008 12:31 PM
jmcturnan
Jul 11, 2006 09:43 PM
