Stock HID Headlight Issues
Old Jan 20, 2010 | 07:41 PM
D's2000A4's Avatar
Default Stock HID Headlight Issues
I have a 2000 A4 with stock (Projection) Headlights. I just bought the car and was told that a headlight was out, Didnt think anything of it, I bought a new one and went to replace it when I noticed that there was no headlight bulb in the socket to be burnt out, I put the new headlight bulb in and nothing, I still get a headlight code on dash and no light. I did notice a little bit of black inside the headlight socket where it looks like a previous bulb may have arked out inside the socket some how. Is there a fuse that could be out or ??? Any help would be apreciated as now Im driving with brights on all the time and getting the finger from everyone!
Old Jan 20, 2010 | 08:20 PM
mikekey's Avatar
I don't think 2000's came with HID's
Old Jan 20, 2010 | 08:41 PM
D's2000A4's Avatar
It has them, and they look stock. Any way to tell?
I looked online it looks like they started the HID in 2000
Old Jan 20, 2010 | 08:59 PM
mikekey's Avatar
Nope you have projectors, Standard on S4 models, and optional on the 01+ A4s.
Old Jan 20, 2010 | 10:00 PM
D's2000A4's Avatar
hmm well either way still need help to fix it. So outside of correcting me do you have any additional info that can help me fix it? I will edit the add to say projection instead of HID. Thanks
Old Jan 22, 2010 | 01:04 PM
pa4ul's Avatar
hid is the bulb used. Projector is the lens that the light goes through. You might have a burnt harness and have to replace it. Have u checked with a voltmeter to make sure u are recieving power to the plug? That would be the first thing i would check besides any other damage to the wires.
Old Jan 24, 2010 | 12:36 AM
D's2000A4's Avatar
the bulb is new. im not getting any power at the bulb, and the fuses are good. Im just gonna have to take it in to have it looked at. Not sure what it could be other then the ballast. Maybe it shorted out and burned up, but either way I cant keep going around with out proper headlights.
Old Jan 25, 2010 | 11:23 AM
pa4ul's Avatar
have u tried swapping the bulbs in each headlight to verify that it is the bulb and perhaps not the ballast. Just trying to save u some $$ instead of taking it to someone and they end up charging you an arm and a leg.
Old Jan 26, 2010 | 05:26 PM
D's2000A4's Avatar
It has a brand new bulb, What it will do now is accationaly come on but if you shut the lights off and then try and turn them back on, they wont come on and there is a humming sound comming from around the headlight
Old Jan 27, 2010 | 11:13 AM
pa4ul's Avatar
I would think ur ballast might be going out. Have u tried swapping them yet. Currently i have this problem but its on my fog lights so ive just not been using them while driving.
Jrmiller
Feb 25, 2013 03:03 PM
snibborfm
Nov 9, 2008 09:40 AM
dombombBMX
Jun 15, 2007 08:07 PM
TBarCYa
Feb 26, 2007 10:06 PM
